Multi-Gigabit Ethernet Overview
The evolution of WLAN technology, from 11ac to WiFi 6/6E and upcoming WiFi 7, pushes wireless connectivity boundaries for improved efficiency and network capacity. To match these advancements, wired speed must also upgrade. Unlike costly 10 Gigabit Ethernet upgrades, Multi-Gigabit Ethernet utilizes existing Cat 5e and Cat 6 wiring, saving expensive re-cabling expenses.
Worry-free PoE Power Budget
Auto-Speed Detection
The Multi-Gigabit technology supports network speeds of 100Mbps, 1Gbps, 2.5Gbps, 5Gbps, and 10Gbps. It enables each switch port to automatically detect the required speed of the connected device.
Budget-Friendly Solution
You can utilize existing Cat 5e cables to upgrade network speed to 5G with the Multi-Gigabit solution, offering a cost-efficient way to increase network speeds by up to 5 times. This helps you save on infrastructure costs.
Affordability Meets Performance
If a 10G upgrade isn't currently feasible, the more affordable 2.5G option delivers a significant improvement in Ethernet speeds for your network.
Experience Multi-Gig in Your Daily Life
You can enjoy high-quality, buffer-free 4K or 8K video streaming and lag-free gaming at home with our 5/8-port 2.5G small switch. In your studio, boost transfer speeds for file backups with our web-managed Gigabit with 2.5G or 10G switch. And for medium to large offices, upgrade to WiFi 6/6E infrastructure with our 2.5G smart managed switch.
5G CPE
Multi-Gig Unmanaged Switch
8K/4K Streaming
2.5G Gaming PC
WiFi 6 AP
Multi-Gig Smart Managed Switch
10G NAS
Security Firewall
Multi-Gig L3 Aggregation Switch
10G Fiber Smart Managed Switch
WiFi 7 AP
WiFi 7 AP
  • 1
    5G CPE
  • 2
  • 3
    WiFi 6 AP
  • 3
    8K/4K Streaming
  • 3
    2.5G Gaming PC
  • 1
    Security Firewall
  • 2
  • 3
    WiFi 6 AP
  • 3
    10G NAS
  • 1
    Security Firewall
  • 2
  • 3
  • 4
  • 5
    WiFi 7 AP
WAX640S-6E
AXE7800 WiFi 6E Triple-Radio NebulaFlex Pro Access Point
WAX620D-6E
AX5400 WiFi 6E Dual-Radio NebulaFlex Pro Access Point
WAX650S
AX3600 WiFi 6 Dual-Radio NebulaFlex Pro Access Point
WAX630S
AX3000 WiFi 6 Dual-Radio NebulaFlex Pro Access Point
WAX610D
WAX655E
AX5400 WiFi 6 Dual-Radio NebulaFlex Pro Outdoor Access Point
NWA220AX-6E
AXE5400 WiFi 6E Dual-Radio NebulaFlex Access Point
NWA210AX
AX3000 WiFi 6 Dual-Radio NebulaFlex Access Point
XS3800-28
28-port 10GbE L3 Aggregation Switch
XS1930 Series
10/12-port 10G Multi-Gigabit Lite-L3 Smart Managed Switch
XMG1930 Series
24-port 2.5G Multi-Gig Lite-L3 Smart Managed Switch with 6 10G Uplinks
XGS2220 Series
24/48-port GbE L3 Access Switch with 6 10G Uplink
XGS1250-12
12-Port Web-Managed Multi-Gigabit Switch includes 3-Port 10G and 1-Port 10G SFP+
XGS1210-12
12-Port Web-Managed Multi-Gigabit Switch with 2-Port 2.5G and 2-Port 10G SFP+
XGS1010-12
12-Port Unmanaged Multi-Gigabit Switch with 2-Port 2.5G and 2-Port 10G SFP+
MG100 Series
5/8-Port 2.5GbE Unmanaged Switch
Armor G5
AX6000 12-Stream Multi-Gigabit WiFi 6 Router
Armor G1
AC2600 Multi-Gigabit WiFi Router
Upgrade Network Speed for Bandwidth-intensive Applications
Our PoE Multi-Gig switches support IEEE 802.3bt (PoE++), providing port power of up to 60W, with a power budget ranging from 375W to 960W, accommodating connections for high-density deployments of WiFi 6/6E and WiFi 7 access points in large offices, hotels, or schools.
Choose from a Variety of Multi-Gig Switches to Suit Any Environment
Our range includes 5-port to 30-port configurations with different port combinations, such as all 10G, all 2.5G, or a mix of Gigabit with 2.5G or 10G. This versatility enables flexible Multi-Gig applications for any environment.
Success Stories
We Also Recommend
The Cost Effectiveness of Transitioning to Multi-Gig Switches
Multi-Gig switches are essential for supporting future high-speed wireless networks, especially with the emergence of Wi-Fi 6, Wi-Fi 6E, and upcoming Wi-Fi 7 standards.
Learn more
WiFi 6E Solution – Smooth, Consistent Fast Connections
WiFi 6E, the extended version of the WiFi 6, provides a huge innovation leap to wireless industry by taking it into a much wider 6GHz radio spectrum for higher capacity, minimal interference, and faster speeds.
Learn more
Faster WiFi 6 that’s ideal for SMBs and prosumers
The new Pro versions of Zyxel WiFi 6 Access Point provide powerful and fastest multi-gig connectivity for small businesses, SoHo, and home offices, offering an affordable high-speed network environment.
Learn more
