Network Security shouldn’t be a gamble
Don’t gamble with your network security.
Protect your network with security that's constantly evolving.
AI & Sandboxing
Sandboxing allows a rapid response to new threats that have not yet been identified and contains them by leveraging from AI and cloud technologies.
Application Security & Control
Provides protection over applications along with providing detailed control over the optimization of application traffic and even block undesirable ones.
Web Security & Reputation Filter
Includes DNS Content Filter features and Reputation filtering, covering IP checking with cloud-synced categories that continually up-to-date with an ever-evolving cloud database. Eliminates blind spots even with encrypted traffic.
Malware & Ransomware Protection
Our anti-malware delivers quick and responsive protection against the latest threats in Malware.
Protect Your Business
Get protection from malware and unauthorized application for your business. Deliver collaborative approch to complex security threats with unufied management.
Internet
Security Firewall
Gigabit PoE Switch
Personal Cloud Storage
11ac Wave 2 Access Point
L3 Aggregation Switch
L2+ PoE Switch
WiFi 6 Access Point
11ac Wave 2 Wall-Plate Access Point
IPTV
IP CAM
10G L3 Aggregation Switch
L3 Access PoE Switch
11ac Outdoor Access Point
Nebula Cloud Networking Solution
Branch
  • 1
    Internet
  • 2
    Security Firewall
  • 3
    Gigabit PoE Switch
  • 4
  • 5
  • 1
    Internet
  • 2
    Security Firewall
  • 3
  • 4
    L2+ PoE Switch
  • 5
    WiFi 6 Access Point
  • 6
  • 7
    IPTV
  • 8
    IP CAM
  • 1
    Internet
  • 2
    Security Firewall
  • 3
    10G Aggregation Switch
  • 4
  • 5
  • 6
    WiFi 6 Access Point
  • 7
  • 8
    IPTV
  • 9
    IP CAM
  • 1
  • 2
    Security Firewall
  • 3
  • 4
    Gigabit PoE Switch with Uplink
  • 5
    WiFi 6 Access Point
  • 6
  • 7
    IPTV
  • 8
    IP CAM
  • 9
    Branch
USG LITE 60AX
AX6000 WiFi 6 Security Router
USG FLEX 50H
USG FLEX Firewall
USG FLEX 100H
USG FLEX Firewall
USG FLEX 200H
USG FLEX Firewall
USG FLEX 500H
USG FLEX Firewall
USG FLEX 700H
USG FLEX Firewall
Network Security
We've Got You Covered from Every Angle
Network Security that's designed with multi-layer protection against threats from both inside and outside your network. Industry leading-edge technologies are used to eliminate blind spots even with encrypted traffic to create a safer access layer for all your users.
Few Clicks Here & There... and You're Up and Running
Speed up and simplify the deployment, manage and maintain your network security with our centralized cloud management platform, Nebula. From synchronizing security profiles to managing user access, Zyxel Nebula is designed to scale with you.
Networking that Works Together to Protect Your Users… Now That’s Smart!
Contain compromised devices before they can create issues with our Collaborative Detection & Response (CDR) service. CDR can allow the security firewall to work in tandem with Zyxel wireless access points to block or quarantine compromised client devices at the network edge.
Simplifying Your Path to NIS2 Compliance
By partnering with Zyxel security solution, you can confidently navigate changes, strengthen cybersecurity posture, and ensure compliance, and protect the integrity of your businesses.
Never Trust, Always Verify
A never trust, always verify methodology also commonly known as Zero Trust is an important step for many businesses, Zero Trust is built from a group of technologies which can be found in Zyxel Security Services allowing secure remote access to your organization’s network by giving a simplified yet powerful user-centric access and control management platform.
Endpoint Security Best Fit for Your Business
Operating with Zero Trust is the best practice across wired or wireless network infrastructures – wherever your employees: HQ, branch offices, on-the-go, or working from home. Together we can help your business maintain continuity and safety. Zyxel service expands network access wherever you are to keep your data always safeguarded.
Success Stories
We Also Recommend
Essential Cybersecurity Insights
Explore our collection of key security topics, tips, and analysis. As the cybersecurity race continues to evolve, our insights will help you understand the latest trends and strengthen your defenses.
Security Monthly Express
Just Connect – Powerful, Effortless, and Scalable Network Connectivity
Nebula Cloud Networking solution allows you to just connect, protect, and manage Zyxel's compatible Nebula access points, security firewalls and switches with our centralized Cloud platform, Zyxel Nebula.
Nebula Cloud
Total Network Protection
Ready to strengthen your defenses? Get all the details in one place with our complete Solution Guide. It covers our full range of products and services to help you secure every corner of your network.
Download Now
Partner Access Circle
Circle helps to simplify our subscriptions services and management by bringing them together.
Access the platform
