The SMART Solution
The WBE660S is equipped with the Zyxel Smart Antenna, which constantly monitors and adjusts connections for each device, ensuring consistent optimal performance. This technology prevents connection inconsistencies and delays caused by interferences.
The backbone of WiFi 7 is essential for providing the required high-speed and high-power connectivity. The Multi-Gigabit PoE switch XS1930-12HP provides 10GbE connection to WBE660S WiFi 7 access point. It supports the PoE standard IEEE 802.3bt (PoE++) and provides up to 60W of port power for WiFi 7 APs.
