What is WiFi 6E?
WiFi 6E, the extended version of the WiFi 6, provides a huge innovation leap to wireless industry by taking it into a much wider 6GHz radio spectrum for higher capacity, minimal interference, and faster speeds.
*WiFi 6E includes all WiFi 6 features, plus:
2.5X More Capacity
2.5 times more spectrum with the extended 6GHz band with no legacy devices
Seven Superwide Channels
Utilizing up to seven additional superwide 160 MHz channels in 6GHz for bandwidth-demanding application
No Interference
No interference from microwaves and the non-6E devices
Improved Performance
Multi-gigabit speeds and ultra-low latencies paves the way for emerging technology connectivity
6E for High-density WiFi
The 6GHz band is ideal high-density environments to maximize WiFi connectivity.
Security Firewall
L3 Aggregation Switch
Multi-Giagabit PoE Switch
WiFi 6E Access Point
  • 1
    Security Firewall
  • 2
  • 3
  • 4
WAX640S-6E
AXE7800 WiFi 6E Triple-Radio NebulaFlex Pro Access Point
WAX620D-6E
AX5400 WiFi 6E Dual-Radio NebulaFlex Pro Access Point
NWA220AX-6E
AXE5400 WiFi 6E Dual-Radio NebulaFlex Access Point
XS1930 Series
10/12-port 10G Multi-Gigabit Lite-L3 Smart Managed Switch
XS3800-28
28-port 10GbE L3 Aggregation Switch
ZyWALL ATP800
ATP Firewall
ZyWALL ATP700
ATP Firewall
ZyWALL ATP500
ATP Firewall
ZyWALL ATP200
ATP Firewall
ZyWALL ATP100W
ATP Firewall
USG FLEX 700
USG FLEX Firewall
USG FLEX 500
USG FLEX Firewall
USG FLEX 200
USG FLEX Firewall
USG FLEX 100W
USG FLEX Firewall
USG FLEX 100
USG FLEX Firewall
Full-stack Product Selection for WiFi 6E Connectivity
A full-stack, full range of product selection includes APs, switches, firewalls, and routers to support WiFi 6E connectivity and paves the ways for existing and emerging use cases.
Zyxel 6E Boost
Zyxel 6E Boost
The 4x4 streams in 6GHz increases more gains in transmit beamforming and receive MIMO to help extend range and ensure the optimal performance, perfect to be used as high-density WiFi and wireless backhaul deployments.
The BandFlex radio design can support either 5GHz or 6GHz by configuration (WAX620D-6E,NWA220AX-6E), making it the most economical choice to fit into your 5GHz coverage as well as futureproofing the use of 6GHz.
Interference Minimization in Product Design
The advanced antenna design (Smart antenna/Dual-optimized antenna) mitigates co-channel interference and adapts antenna patterns to ensure the optimum performance.
The advanced RF filter design removes interference between the 5GHz and 6GHz bands, guaranteeing performance in all channels in either band concurrently.
Secure Connectivity
Secure Connectivity
In addition to the latest WPA3 standard, Zyxel offers many security add-on features like Secure WiFi, DPPSK and more to keep your employees, guests, and network safe.
Nebula, The Intelligent Cloud Management
Zyxel Nebula cloud supports a comprehensive range of products from AP, switch, security firewall, to 5G/LTE mobile routers, offering both intuitive web interface and mobile App to deliver a streamlined experience for installation and management of your network, without additional cost for a software or hardware controller.
Success Stories
We Also Recommend
True backbone of WiFi 6/6E
WiFi 6/6E needs higher speed LAN (>1Gbps) and power (PoE++). The Multi-Gigabit PoE switch XS1930-12HP supports the latest PoE standard IEEE 802.3bt (PoE++) providing port power up to 60W for WiFi 6/6E AP, as well as maintaining backwards compatibility with existing PoE/PoE+ devices. With a large power budget of up to 375W, XS1930-12HP gives enough headroom for connections up to 8 WiFi 6/6E APs.
Learn more
Secure WiFi
Secure WiFi
With secure WiFi, you can easily and securely extend working experience as if you were in the office with the adoption of secure tunneling and strict two-factor authentication.
Learn more
